12-13-2013
22:17
19:14
EstuardoFitbit
12-13-2013
22:17
19:14
EstuardoFitbit
Moderator edit: format
11-28-2015 14:19
11-28-2015 14:19
11-28-2015 14:42
11-28-2015 14:42
Kdag,
@Kdag wrote:
Then sometime in the night or next day my fitbit turned up missing! I was in the mountains so it never synced...:-( ... Does this mean I have to do it again next summer? Ahhhrrgghh...!!!
Did you lose it in the mountains, or it just didnt' sync because you didn't have a cell connection and you lost it after getting back home?
The answer is important because if you can find it before the battery dies, you can still sync and get credit. Fitbits hold up to 7 days worth of detailed data (minute by minute statistics) then switch to daily summaries for up to 30 days. So you can actually go up to 30 days without a sync and still get the credit. However, unless using a model like the Zip that can go months on its internal battery, you are more likely to have it run out of battery and lose statistics.
For example, if you go on a 10-day cruise without internet, just take along your charger and keep the device charged. Sync when you return home and you'll have the full detail for the most recent 7 days, and daily totals for the days prior to that.
So if you have lost it at / near home, do your best to find it. What I recommend is using an app on a smartphone which can display all Bluetooth Low Energy (BLE) devices that are in range. Then you wander around the house or car or retrace your steps waiting for your Fitbit to show up as in range of the phone. Then you move around watching the signal strength to the fitibit change and play a sort of hot-vs-cold game until you have found the maximum signal strength. The fitbit should be hding within reach at that point. (I've used this method several times to find it in the laundry or fallen inside a coach or whatever.)
There are many BLE scanners in the app stores, many free. Plus at least one geared specifically for finding lost Fitbits, though I think that one is a paid app. I like LightBlue and BLE Scanner myself.
PS: Congrats on the steps! I've only got past 50K once myself, and that too was to get my lifetime highest step badge. I was going for 100K, but got a bad enough blister after 93K that I called it quits...
11-28-2015 17:07
11-28-2015 17:07
11-29-2015
04:28
18:17
EstuardoFitbit
11-29-2015
04:28
18:17
EstuardoFitbit
11-29-2015 04:31
11-29-2015 04:31
11-29-2015 04:34
11-29-2015 04:34
11-29-2015 12:55
11-29-2015 12:55
I have read some comments that the steps do not add up when on a treadmill ? My husband goes on a treadmill twice a week and was wondering where to put his fitbit to make the steps count, I suggested maybe his pocket but if it works on his wrist all the better. do you wear yours on your wrist while on the treadmill Vodka01
11-29-2015 12:59
11-29-2015 12:59
11-29-2015 13:50
11-29-2015 13:50
that is good I will tell him that. Cheers
11-29-2015 14:07
11-29-2015 14:07
While it is somewhat to loosely use your hands to help balance on a treadmill, grabbing the bars can reduce calorie burn, throw the back out of alignment, cause reparative use injury to the knows and ankles it can also prevent the body from l learning to find time the balance, making it easier to get injured while doing a free rim outside.
11-29-2015 18:28
11-29-2015 18:28
that is interesting info. but my husband needs to do the treadmill with while attached to oxygen at the hospital due to COPD, it would be against the hospital rules .
11-29-2015 22:44
11-29-2015 22:44
Like they say there are always exceptions, not knowing the circumstances of your husband's case, a hospital was never mentioned, I was giving info based on current and past studies.
11-30-2015 12:20
11-30-2015 12:20
I've also put the Charge in my pocket whilst on the treadmill, as mentioned by @SunsetRunner (nice username, by the way). I need all the steps I can get in the challenges, and my phone is always on the treadmill tray for when I need to check those stats. I always like to see the steps gained in increments after 20 minute without syncing.
12-01-2015 07:35
12-01-2015 07:36
12-01-2015 07:36
When you rather prefer going to a mountain trip instead of a party!
12-01-2015 07:54
12-01-2015 07:54
When you leave your Fitbit home, and your arm feels as naked as you would feel as if your only in underwear.
12-01-2015 08:09
12-01-2015 08:09
This is super real @Rich_Laue. I took a shower this morning, and charged my Fitbit devices at the same time. I looked at my wrist, and it felt so weird.
12-01-2015 15:49
12-01-2015 15:49
LOL @Rich_Laue, that happened to me today, I forgot my Charge HR at home today .
