It's great to see that you've visited the Fitbit Community @SunsetRunner. There is actually no option to manually correct/edit your active minutes, however you can manually log an activity in the Activity board and this will modify the total of your active minutes depending on the intensity of the activity.
Additionally, I would recommend performing a restart to your One by following @Odyssey13 instructions. This might help to avoid having this situation in the future.
Thanks for stopping by, see you around. ![]()
Hello @SunsetRunner, it will depend of the activity you are logging but most of them will give you active minutes, even if you are using a third party app to manually log exercises. I wonder if the restart that my friend @EdsonFitbit provided before has resolved the issue or if the issue with active minutes still persist on a daily basis?
Hope everything is working fine and see you around. Keep me posted how it goes.
