01-31-2016 22:37
01-31-2016 22:37
Best Answer02-01-2016 00:53
02-01-2016 00:53
Replacements may be refurbished.
I'm not sure if the warranty is the same everywhere but in the UK it says:
"If a hardware defect arises and a valid claim is received by Fitbit within the Warranty Period, Fitbit will, at its option and to the extent permitted by law, either (1) repair the Product at no charge, using new or refurbished replacement parts or (2) replace the Product with a new or refurbished Product."
You can check your warranty at www.fitbit.com/returns
02-01-2016 02:31
02-01-2016 02:31
Hi, @Ocsbs , I think you have had a somewhat unusual experience. The Fitbit One is mostly very reliable. I wonder if you have tried the restart procedure ? That might get you back going again. Sometimes it takes two or three tries, and do be sure that you hold the button for long enough (it says 10-12 seconds, but can actually take 20-30)
06-07-2016 04:43
06-07-2016 04:43
Welcome @Ocsbs. As @SteveH mentioned and to clear thing up a little, replacements from Fitbit may involve either new or refurbished materials, depending on the situation, and this apply to all the countries where the tracker can be replaced directly by Fitbit. The difference between UK is the period of warranty, as in some countries is for 365 days, in European Economic Area is for 2 years.
In case you received a refurbished tracker, first is thoroughly tested and sanitized, to make sure they don't have any technical issues. So I wonder if the great suggestion from @Julia_G have worked to resolved the issue with your One?
Hope everything is fine and keep me posted if something is not working as it should.
