08-22-2016 10:39
08-22-2016 10:39
My Fitbit One has regularly lasted 14 days between charges, but over the last couple of weeks I've only been getting 2-3 days out of it before it dies. I'm guessing this is due to it's age - it's 3 years old now and I've used it every day.
I know I can't change the battery, I've done a restart and made sure I'm on the latest firmware, so not sure there's anything else I can do, but before I replace it, I thought I'd check with the community to see if anyone has any ideas?
Thanks, Hank
08-23-2016 06:31
08-23-2016 06:31
Hi @SunsetRunner
Check out the Fitbit Help Article:
URL: Click to go to the Fitbit Help Article 'My tracker's battery isn't charging'
How to clean the tracker? YouTube Video (By Craig) (For flex but similiar for other trackers)
http://www.youtube.com/watch?v=ezvXy9mKoGQ
Hope it helps
Best Answer08-23-2016 11:25
08-23-2016 11:25
Hi
Thanks for the response.
There's no problem charging the battery, it charges to full in the usual sort of time, it's how quickly it discharges that is the problem.
I logged a ticket with Support too, I'll see what they come back with 🙂
Hank
08-23-2016 11:29
08-23-2016 11:29
Maybe your 'buddy' needs a vacation.. ![]()
Hope you hear from them soon. ![]()
Best Answer08-23-2016 12:44
08-23-2016 12:44
I was having the same issue with a much newer Fitbit One (8mths old). I just did a chat with support and its getting replaced.
08-30-2016 18:25
08-30-2016 18:25
Best Answer09-03-2016 05:01
09-03-2016 05:01
Exact same circumstances, Hank. Except yesterday, Fitbt One died completely--no image, nothing happens when button is held, being in charger does nothing. Been through all the Fitbit online help, but nothing works. Wish I could return to Fitbit Ultra; never a day's problem. But Windows 10 does not support. Looking forward to your results in trying to restore. Please post it. Thanks.
16:59
05:59
09-05-2016
16:59
05:59
@StormyKrista welcome to the forums! I'm relieved to know that our Support Team will be replacing your One tracker so you can get back on track as soon as possible! I'm sure this replacement will work excellent for you. When charging your tracker, please make sure that you are plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker.
Greetings @a1bonita!
Just out of curiosity, have you tried restarting your One? that might do the trick! If you haven't already then please do so by doing the following:
Also, cleaning your contacts helps your tracker to better charge. Please make sure that you clean your charging contacts by doing the following:
Clean the pins on your charging cable, just to be on the safe side:
After that make sure your tracker charges for at least an hour, Keep an eye to your tracker's behavior and if it keep doing the same, please contact our Support Team for a second opinion. They definitely have the proper tools to take a deeper look into your tracker's behavior. Mention them all the troubleshooting steps you've followed to fix this so they can move forward to the next step. Keep me posted!
@BubbeBird thanks for joining the conversation! The good old Ultra, right?
But to be really honest I've never had any trouble with my One and I love it so much! ![]()
If you haven't already, please try the following:
1. Press and hold the button on your One for five seconds. If it does not turn on after doing this, place your One into the charging cable.
2. Ensure that your charging cable is plugged into a working USB port.
3. Make sure that the gold contact points on your One align with the gold contacts on your charging cable, and let the device charge for at least an hour.
4. After charging your One, press and hold the button on its display button for 15 seconds, leaving the tracker plugged into the charging cable.
5. Take the tracker out of the charging cable and hold the display button for 5 seconds.
I really hope this helps, keep me posted! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer09-05-2016 19:09
09-05-2016 19:09
This happened to my fitbit a few months ago.
2 things to check.
1) do you have alrarms set? i had a daily and weekly alarms set. those can drain a battery quickly if left to buzz ...
2) where to you wear your Fitbit? on the belt clip or in a pocket? I kept mine in my pocket (all the time) and sometimes it can rest on the button a bit too long and send it into "sleep monitoring" mode, that along with the button press lighting the screen up all the time, can also darin the battery quicker than ususal.
Those 2 issues were the main cause of my battery lasting less than a week!!
Best Answer09-06-2016 10:09
09-06-2016 10:09
I'm not having any issues with charging. It charges fully. I don't have any alarms set, but I do wear it clipped to either my pocket or waist facing inward. It isn't usually already lit up when I look at it, but I'll take look at whether that could be contributing to my battery life issue.
13:21
05:59
09-08-2016
13:21
05:59
@s0litaire welcome to the forums! It's great having you around.
Thanks a million for sharing this with the rest of the Community. Those tips are very important when it comes to save battery.
@a1bonita please give a try to what @s0litaire is suggesting and post back with the results!
Catch you later guys! ![]()
