I am having the same problem. I restarted my One following fitbits instructions--charging cable into computer, one into charging cable. Hold button 10-12 seconds, remove from charging cable. Hold button until screen turns on. Then I restarted my phone. Restarting both finally worked for me--nothing else did. Lost a week of data BOO! but it is synced and working. Clearly some kind of update failed us.....
This happened to me as well, right out of the blue. It said I had to do a software update, which I did but then it just started to shut itself off. I missed two days of workouts because I thought it was on when it wasn't. Was there something a miss with the software update? Just wondering.
Best Answerhi i am having same issue with new $155.00 replaced fb one from ebay. what i don't see is what did you to resolve this problem. please share the instructions. i am getting so frustrated with fb because its so difficult to support. thank you,
Best AnswerAs the banners have been stateing moderators presense will be spotty. Also in general they do not know more than what they have been told or under an NDA.
As for contacting Apple, I'm not sure how for that will go when in version 10 apple quietly released a few changes that messed up notifications for Fitbit, Garmin, and other third parties.
I don't know much about iOS and would suggest looking at the iOS board.
As for sync and the phone, it is the app / iPhone connection not the tracker model.
My response was that the user can not pair the phone through the phones Bluetooth, if the user does, the app will not be able to find the tracker.
