12-21-2017 13:42
12-21-2017 13:42
Is the Fitbit one compatible with the new IPhone X?
Best Answer12-21-2017 20:16
12-21-2017 20:16
You can check here:
https://www.fitbit.com/devices
Wendy | CA | Moto G6 Android
Best Answer12-21-2017 23:48
12-21-2017 23:48
No. I'm running iPhone X 11.2.1 software update. Updated Fitbit 1 software, app updated.
Uninstalled, reinstalled app on my X, no change. Fitbit 1 will not sync with my iPhone X. Must manually input all data online. Any data input on the Fitbit app on my X will not communicate or sync with the online Fitbit dashboard.
G. Chase
Best Answer12-29-2017 04:28
12-29-2017 04:28
I called FitBit customer service and they walked me through uninstalling and reinstalling the app on my IPhone X. Everything is working fine now.
Best Answer12-29-2017 04:30
12-29-2017 04:30
The key is to turn the IPhone X off after you uninstall the app. Then turn it back on to reinstall the app.
