02-08-2016 11:06
02-08-2016 11:06
My daughter has an ios and we both now have the fitbit one. She has the option to push notifications from her iphone that I don't. She can determine what options show up on her fitbit while I can't. I don't see the option to have it set for right or left hand or what infromation I want to see on the trackter (such as the flower, time, greeting, etc.) I can see sort this information on the web but not on fhe app within my android phone.
Best Answer02-08-2016 11:33
02-08-2016 11:33
Hello @Tastysnack,
While I have neither an iOS nor Android device, I think I can help. Try this:
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best Answer02-08-2016 11:46
02-08-2016 11:46
Thanks for your help. Unfortunatly when I attempt to perform the steps you suggested I am not greeted with the same messages. When I tap on the tracker image it only has the option to sync now, all day sync, silent alarm, and modifictation of greeting. With my daugter's phone (iphone) - I see the other options you suggested.
Best Answer02-08-2016 11:51
02-08-2016 11:51
Ahh... I have a Windows Phone, and they're there. I would've expected them to be there on the Android app.
Truthfully, while in a perfect world, they would be there. I would just change them on the online dashboard (which should still be available on your phone's browser), I think you'll find that you'll only change it every great once in a while.
If there is a way to do it, you should post in the Android part of the forum, where it'll get more attention by Android users. Or if you'd like, I can move this post. Just let me know.
