02-18-2017 06:07
02-18-2017 06:07
Picked up my Fitbit one this morning to get started and it said I already got in 21,000 steps!! While that would be great how do I fix it?
05:10
10:48
02-20-2017
05:10
10:48
Wow, that is a lot! Can you see from your dashboard when those steps came in?
Was your One near a vibration source such as a fan, or perhaps sitting on top of your washer or dryer? That could account for the steps...
02-20-2017 12:47
02-20-2017 12:47
Best Answer02-20-2017 13:51
02-20-2017 13:51
That was the reason, then, and mystery solved! When you aren't wearing it, keep it away from vibration sources... Happy stepping!
02-20-2017
13:54
10:46
02-20-2017
13:54
10:46
ps, if you would like to negate those steps, check out the time period they were detected and then log driving. Frankly the procedure is a little cumbersome, but it really does work if you are very careful to follow the instructions and make sure you search for and find the built in database driving activity and get the timing right.
You may decide it is not worth the bother for one day's dodgy data.
