07-17-2018 04:00
07-17-2018 04:00
Hi,
My FitBit One completely died normally and I haven't used it in a couple weeks. I went to plug it in to its charger and it is not working. I've held down the button and it won't turn on either. Is there anything else I can try?
Thank you!
Best Answer07-17-2018 11:30
07-17-2018 11:30
Clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart do this 3 times
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Hopefully it helps. How old is it?
Wendy | CA | Moto G6 Android
07-29-2018
13:39
08:40
07-29-2018
13:39
08:40
@kpappas789 Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing with One not responding to taps and not charging.
Please try the suggestions given by @WendyB as this has helped other users in the past and should help you as well.
I also went ahead and contacted you via PM. Please keep an eye on your Community inbox.
Keep me posted! ![]()
07-01-2019 04:24
07-01-2019 04:24
Wendy you are a star! I was just about to give up when I tried the restart thing 3 times and it came to life!
Can't live without my Fitbit one. Now looks like its charging. Thank you.
