03-16-2019 10:32
03-16-2019 10:32
Like many others I was devastated when my fitbit endured an hours cycle in the washing machine. However I left it in rice in the airing cupboard for a week and amazingly it's working again!! I kept trying it each day but it was only after 7 days that it came back so don't give up hope.......
03-16-2019 21:51
03-16-2019 21:51
Glad it came back!
I did this 3 years ago and put mine in rice for a few days and its still going strong to this day ![]()
Wendy | CA | Moto G6 Android
03-17-2019 08:54
03-17-2019 08:54
I have washed and dried mine a few times by accident and it didn't hurt mine at all.
01-11-2020 01:15
01-11-2020 01:15
Mine won't turn on or charge
Best Answer01-11-2020 14:19
01-11-2020 14:19
@NoMrk Put it rice for at least 48 hours and see if it helps
01-12-2020 05:02
01-12-2020 05:02
The same thing happened to my Fitbit one but I was lucky and it worked after just drying the outside of the device.
01-14-2020 18:06
01-14-2020 18:06
mine went through the washer and dryer twice and survived a dive into salt water. Doesn't hold the charge so well, but.. hopefully yours will come back.
05-28-2021 16:48
05-28-2021 16:48
Hi,
So my Fitbit 1 just went through the washer & drier for the 1st time. It is working, however, I am wondering, should I put i in rice for 24 hours? Thought? Please advise. Thanks much,
Cory
05-28-2021 16:51
05-28-2021 16:51
Oops, sorry for the typos; my brain is faster than my very poor typing skills!
Best Answer06-07-2021 06:05
06-07-2021 06:05
I would try just incase.
07-22-2021 15:33
07-22-2021 15:33
Mine is going strong after washing it in washing machine. I did not even try drying it
Best Answer07-23-2021 15:25
07-23-2021 15:25
Some Ones are better sealed than others. I've opened well over 100 Fitbit Ones and sometimes there's a solid bead of glue around the perimeter, often times though, it's more of a dotted line, which retains the case but doesn't waterproof it. On the other hand, I've over-glued Fitbits from Ones to Charge and made them waterproof 🙂
07-29-2021
18:27
05:28
AndreaFitbit
07-29-2021
18:27
05:28
AndreaFitbit
That's interesting. My One is working, but holds a charge for maybe one day or two, at the most. Before the washer/dryer episode, I only charged it every 7-10 days.
I have never opened my One. Sounds good to me, however, what are the steps (i.e., how does it open, what tool to use, etc.)? Also what type of glue works best? Please advise.
Thanks much,
Cory
Moderator edit: Removed personal information.
Best Answer09-06-2021 17:55
09-06-2021 17:55
Hi @CoryCD I hope you're well. I'll see your replies sooner if you 'tag' me. It's probably one of those "correlation isn't necessarily causation" things with your One's battery life and the washing machine as the water would either destroy it or not. The nerd in me wants to mention water doesn't damage our Fitbits, electrolytes in water cause metals to corrode (pure water isn't harmful but is rare). OK pardon my digression, LOL opening the one requires a razor blade and patience. There's a seal around the top and bottom sections that will come apart. I've done older Ones with my fingernail and not even needing the blade but the blade is great as it removes all the glue if done properly, just be careful to not cut yourself. If any glue remains, just use 99% isopropyl and a microfiber cloth to remove while separated from the electronics. The best adhesive to reseal the One is B7000. Tools: required are soldering iron, razor blade, adhesive. Recommended tools include a nice soldering mat so you don't burn your table and a clamping "helping hands" setup. Personally, I tend to don a watchmaker's headband with lights and a magnifying glass when working on Fitbits. I've also gone MacGiver on them before with hands and lighter instead of soldering iron and professional tools, but that was to show off LOL use tools. This first picture shows both a good (but detached) OEM One battery and the puffy ones that I've seen in >80% of Ones I've refurbished. Ask any questions, always eager to help out fellow Fitbit One aficionados get back up and stepping!
Always good to test before glue!
Difference in original/new battery
Opening up the Fitbit One before replacing battery
Best Answer09-06-2021 18:08
09-06-2021 18:08
14:03
15:21
BraulioFitbit
09-07-2021
14:03
15:21
BraulioFitbit
It still works, but holds a charge for 2.5 days max.
Cory Calandra Devereaux
Artist/Muralist
Moderator Edit: Personal info removed
Best Answer09-10-2021 05:54
09-10-2021 05:54
Hi, @CoryCD , this is most likely due to the age of the device rather than it having been through the washing machine. All rechargeable batteries do deteriorate over time. You can maximise the lifetime of your battery by avoiding deep discharges as much as possible.
Best Answer07-14-2023 13:38
07-14-2023 13:38
@WilligerAny advice for a recently-washed FitBit one which almost/sort-of works? I've washed it accidentally before, and it had come out OK. This time, it won't reset. It shows "FITBIT 6.64" if I press button after plugging in to power, and power bar briefly (full). BUT, it won't start on press/hold of button. I've also tried 12-second hold to reset when plugged in, and that doesn't seem to do anything. I have not yet done the rice therapy. Any other advice? Thanks in advance.
Best Answer07-14-2023 14:00
07-14-2023 14:00
Best Answer07-14-2023 16:27
07-14-2023 16:27
@kiloJoe don’t put it on the charger until it has had the rice trick for at least 48 hours (I’d give it 72), then charge, then reset. I bet it will work! Good luck!
