The usual things to try when you get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
Hopefully you'll get this resolved soon as the One only has enough storage to hold detailed data for up to 7 days between syncs. After that it starts holding the data at a daily summary level.
