03-11-2018 15:29
03-11-2018 15:29
My Fitbit is not syncing with my computer, iPad or iPhone. Is there away to fix this?
Best Answer03-12-2018 01:01
03-12-2018 01:01
If it's not syncing to any of your devices the chances are that it's an issue with the fitbit. I would try restarting it:
You may need to give this a few tries as it's known to not always work.
03-12-2018 01:01
03-12-2018 01:01
03-14-2018 21:10
03-14-2018 21:10
Thank you to Steve H for your help. I have been searching for hours for help, and your advice worked.
03-16-2018 11:13
03-16-2018 11:13
Thank You for helping me getting my lifeline working
My Fit-bit keeps the challenge going So Happy
Best Answer03-18-2018 04:30
03-18-2018 04:30
Thank you for you help this was really useful did it on the first attempt will remember this for future.
Best Answer03-19-2018 07:13
03-19-2018 07:13
This does seem to work but why do I have to do this at least once a week? This happens on a regular basis with my fitbit now. 😞 Is there a permanent fix?
Best Answer03-19-2018 11:21
03-19-2018 11:21
