My fitbit one will not sync to my android app. I can see that there is a new software update but I can't get that to work either...
I would try restarting your One using this procedure:
Give it a few tries though as the procedure sometimes doesn't work. Once it's connecting again it should prompt you to try the software update again.
Best AnswerI have tried this and it does not work. This happened with my old Fitbit One in August and eventually Fitbit replaced it, although it started with and Android software glitch.
