04-02-2016 14:13
04-02-2016 14:13
04-02-2016 14:55
04-02-2016 14:55
Mine is doing the exact same thing. Except I use mine everday. It says Fitbit 6.6 and the battery charged as soon as I unplug it the screen goes blank. I've gone through all the steps of restarting it and it doesn't restart, it does nothing. When its plugged in it sync and the app says its fully charged but when I unplug it it won't sync so I know it's not just the screen. I sent an email to fitbit support hopefully I get an answer soon.
Best Answer04-05-2016 18:58
04-05-2016 18:58
Mine is the same, if the fitbit is plugged, it works and the battery says full but as soon as I unplug it, it dies
Best Answer04-05-2016 19:20
04-05-2016 19:20
I sent an email to support and they looked into my account and seen it was't working properly so they are sending me a replacement. I would do the same if I were you. Good luck!
04-07-2016 09:16
04-07-2016 09:16
Hey guys @Logikel83 @Phillies @mdss2, welcome to the Fitbit Community
! I'd recommend the same as @Logikel83, the best suggestion is to get in touch with Customer Support directly.
They will be more than glad to give you a hand on this, just don't forget to mention the steps you've done so far to avoid getting the same ones.
Happy stepping!
