How old is it? They do die after 2-3 years.
their is always the inspire with the clip that's just like the one
Wendy | CA | Moto G6 Android
Best Answer@Niecy92 @If the battery completely drained, it's likely the charging circuit will be unable to resurrect the battery. Best to always keep it a bit charged. You can do a DIY replacement, most trackers are perfectly fine, it's just the battery expired, which is quite common with that type of battery after 2-3 years. Alternately, fitbit's lower cost unit, the inspire, appears to be their closest current replacement. Cheers!
