Hi @jnic312.
I think that you have to re-visit your weight goal and the time frame that you chose to achieve it in order for your day-to-day metrics showing on your dashboard to make more sense. A weight loss of two pounds per week is extremely aggressive, hence I'm not surprised at all that your dashboard would show that you're under target to the the tune of two to three thousand calories.
So my suggestion is to start with a more realistic weight goal and time frame as opposed to shooting for the moon from the get go. For example, suppose you want to loose 50lbs over the next 12 months. Well, one pound a week, with a target date a year down the road would achieve that and would give you realistic numbers on your dashboard. But for me, I would prefer to segment that goal into smaller bites, like losing 10 pounds over the next three months. If you get there sooner, then that's great; then you can reset your next target, again making sure that your timeframe for achieving it is reasonable.
Does this help any?
TW
____________________________________________________________________________
(If this tip solved the problem for you, please mark this post solved, as this will be helpful to other users experiencing similar issues.)
