Hi -
Thanks,
Eliezer
Fitbits can hold 7 days of detailed data between syncs. If it goes unsynced for more than that it can also hold up to 30 days of data but only at a summary level. So, ideally you sync at least once per week.
When you do sync all the data is copied from your fitbit to the fitbit servers so that's always safe. If the battery runs very low it will effectively switch off and stop recording data but the data on it should be safe as there will still be a small amount of battery power left.
@SteveH, thanks for your reply!
You wrote:
"it can also hold up to 30 days of data but only at a summary level"
Does that mean the total number of steps taken in each of the 30 days?
Any idea about how many days that is?
Thanks,
Eliezer
I've not seen the summary level data but I think you are right, you get just the total for the day rather than the normal minute-by-minute data.
Sorry, but I don't know how long the battery holds any power after it automatically closes down. Hopefully someone else will post with more information on this.
The Fitbit Tech I spoke to also said the information would be held for 7 days, but mine is only holding two. I synced at 11am last Saturday and again at 2 pm yesterday (away on vacation), and only Friday and yesterday's information was recorded/synced. Is there anything special I need to do?
