If that doesn't do the trick then you could try restarting the fitbit too using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give it a few tries as it's known to not always work.
In terms of the warranty: it depends where you live, some places are covered by 12 months, others by 24. You can check the terms here: www.fitbit.com/returns
Best AnswerI have that problem sometimes with my android as well. Sometimes rebooting the phone helps. Other times I try to synch it ten, fifteen, twenty times until it finally does synch.
