So my tracker is no longer showing me the low batter icon. The only way I know my battery is low is if I get a notificiation via the app or email. Used to be if I recevied one of these notifications I would press the button on my tracker and it would show a battery with a low level. It no longer does this. Can any one tell me what is going on and how to fix this.
Hello @ashowers36,
So I just started to get the low battery indicator on the tracker itself (notice no charging cable attached):
And I got it around 8:30am, my original low battery e-mail/notification fired off yesterday at around 10:30am. So around a 22 hour difference. I never timed it before, so I did it this time since I was curious.
I know that I've continued to use it for a few hours after the display changes, so good to know that I have at least a full day's use (24+ hours) after I get the low battery e-mail.
If I were to speculate, the e-mail/notification fires at around 20% battery and the One's display changes once it's under 10%.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Try a restart. Sometimes doing it a few times helps.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
Best AnswerI have restarted it several times now. It still does not show the battery icon. 😞
Hello @ashowers36,
My observation from my use of the Fitbit One is that the low battery warning on the device (battery meter when you press the button) shows up a few hours after the low battery notification shows up (on both e-mail and Fitbit App).
As it happens, my low battery notification went off this morning at about 1/2 hour ago. I would expect the display on the One to change in maybe another 3-4 hours.
If you noticed that this is much closer for you in the past it is probably a function of how frequently you sync.
I'm curious as to how much longer before the display changes, so I'll hold off charging it until then and report on this thread.
I hope this helps.
Best AnswerWell I received the notification via email/app this morning around 7:00 EST. It is now 2:22 P.M. EST and the tracker still does not show up with the battery icon. I know it is syncing because both the dashboard online and my app show battery level as low. Just not my tracker itself.
Hello @ashowers36,
I hope this helps.
