03-07-2017 06:15
03-07-2017 06:15
Recently had a total knee replacement. My fitbit one no longer keeps an accurate step count (only counts less than half of my steps and counts no flights at all) I thought it was the device itself and ordered a new one and the new one does the same. It does not count any steps if worm clipped to my bra and only works some if in a pocket. I never had a problem before and am puzzled.
Best Answer03-07-2017 06:22
03-07-2017 06:22
Are you using a walker or a cane?
I have the same problem as I had a Hip replacement. I do use a cane but it is also because I'm not picking up my feet like I normally do. It will get better once you heal. Just dont worry about it now
Wendy | CA | Moto G6 Android
Best Answer03-07-2017 06:27
03-07-2017 06:27
Thanks for your reply. I'm not using a walker or a cane. Almost five weeks out and my gait is normal just walk a bit more slowly. The flights I almost understand as I only go up one step at at time. My Iphone give me accurate steps, but I don't carry it with me all the time. This is irritating.
Best Answer03-07-2017 07:24
03-07-2017 07:24
You said you are going slower. Just give it time
