12-17-2019 16:37
12-17-2019 16:37
No device found
12-17-2019 23:21
12-17-2019 23:21
Go in on your phone and turn Bluetooth off
Shut phone down for a minute.
Go back in and on the Fitbit device tap the Icon that shows your Fitbit. Look for Sync now. Tap that and let it turn Bluetooth back on.
Wendy | CA | Moto G6 Android
12-17-2019 20:28 - edited 12-17-2019 20:28
Can we get more info? Like what phone you are trying to set it up on?
12-17-2019 23:10
12-17-2019 23:10
My fit bit one is set up to samsung phone. NOT syncing know said not found
Best Answer12-17-2019 23:21
12-17-2019 23:21
12-20-2019 13:57
12-20-2019 13:57
I'm having the same problem with my one on my Samsung galaxy phone. I tried the reset listed above but it still doesn't work. Had no problem prior to yesterday.
12-20-2019 22:11
12-20-2019 22:11
This worked for mine. Thank you so much!
Best Answer12-21-2019 14:07
12-21-2019 14:07
I had the same problem this week after updating the App.
In my case the solution was to reset/restart the Fitbit One
Best Answer12-21-2019 23:18
12-21-2019 23:18
I’m having the same problem and have tried both of the suggestions in this thread but not having any success. Any other suggestions please?
Best Answer12-22-2019 01:15
12-22-2019 01:15
