06-09-2019 17:26
06-09-2019 17:26
My One last synched on 6/4 and for some reason has not since then. Any tips for getting it to sync again? For reference I'm using the Fitbit app on my LG G5.
06-09-2019 17:38
06-09-2019 17:38
Following, My hasn't synced since Friday!
06-10-2019 16:30
06-10-2019 16:30
My One wont sync. I'm on a Galaxy 7 Edge the just had several updates. Hasn't synced since early Friday morning. Ugh.
06-12-2019 09:17
06-12-2019 09:17
Check for Fitbit app updates
Restart phone
Restart One
Go to your Bluetooth settings on the phone, remove the Fitbit One.
Still not syncing?
Open the phone settings, apps, Fitbit, Storage, Clear cache.
Restart phone
Try a sync.
Remove the Fitbit app if you know the login
Install fresh copy of app, especially if it was a phone update. I see no mention of what type of updates received
Keep us informed guys.
08-23-2019 05:25
08-23-2019 05:25
I have Google Pixel 2 running stock Android 9 with current OS updates.
The Fitbit application stopped syncing after the August 15th update. I had to restart my Fitbit One, uninstall the Fitbit application, reinstall the Fitbit application, and restart my phone for the Fitbit application to recognize my Fitbit One. (I think the phone restart did the trick.) After all that the Fitbit application connected and was able to sync.
I thought that I would share some positive news.
08-24-2019 05:41
08-24-2019 05:41
Restarted iPad. Uninstalled app. Reinstalled app. :white_heavy_check_mark:
