02-22-2019
04:57
05:44
SantiR
02-22-2019
04:57
05:44
SantiR
Hi. I have a fitbit One that works but the display does not. I'm trying to set it up and it asks for the 4 digit number on the display. Is there any way of getting past that.
Thanks
Moderator Edit: Updated Subject for Clarity
02-22-2019 05:06
02-22-2019 05:06
I don't think there's a way round that.
Have you tried restarting the fitbit in the hope of getting the display working again? Here's how:
02-24-2019 05:26
02-24-2019 05:26
@Allen1958 Welcome to the Fitbit forums! Thanks for reporting the situation you are experiencing with your One's display not working.
By any chance, have you tried the suggestions shared by @SteveH already? It is necessary that you try those steps to see what happens and determine what to do next.
Please let me know the outcome of this! ![]()
03-02-2019 06:30
03-02-2019 06:30
Yes I’ve done that many time and I know the display is not working. I did have the One set up on my phone when the display stopped working so I was able to still use it. Now I have a new Fitbit and wanted to set it up on another phone but without the display I can’t get the code to complete the setup. Thank you for the replies but I don’t think I’ll be able to set it up.
Best Answer03-03-2019 11:58
03-03-2019 11:58
@Allen1958 Thanks for your reply and for trying all of the steps provided. Thanks for sharing those details.
I went ahead and contacted you via PM. Keep an eye on your Community inbox for next steps.
Keep me posted! ![]()
Best Answer03-04-2019 19:23
03-04-2019 19:23
My One quit displaying today. I was able to use the restart as directed below. It worked and I now have my display back.
Best Answer03-05-2019 05:10
03-05-2019 05:10
Best Answer03-07-2019 14:38
03-07-2019 14:38
@loriruns @Allen1958 Thanks for visiting the Fitbit Community. Sorry for the delayed response.
@loriruns I'm glad to hear that your Fitbit One is working fine after performing a restart. Thank you for letting us know.
You are welcome to visit the Discussions board where you will find interesting topics to join.
If you have any question, please don't hesitate to contact us back at any time.
Best Answer05-20-2019 16:53
05-20-2019 16:53
I have tried the restart but to no avail. Is there anything else I could try?
Best Answer05-20-2019 19:12
05-20-2019 19:12
Best Answer05-21-2019 05:36
05-21-2019 05:36
Hello SantiR,
I have exactly the same issue with my Fitbit One.
I've tried all the steps described by SteveH. Unfortunately, nothing worked.
When I put it on charge through the PC the message appear on the screen Fitbit 6.64 and the battery is fully charged. It doesn't sync anymore either.
Any help would be appreciated.
Best Answer05-21-2019 05:42
05-21-2019 05:42
Hello SantiR,
When I put it on charge the message appear on the screen Fitbit 6.64 and that the battery is fully charged. It goes blank straight away. It doesn't sync anymore.
I've tried all the steps from SteveH post. Unfortunately, nothing worked.
Any suggestions would be appreciated.
Best Answer05-21-2019 18:14
05-21-2019 18:14
I just purchased a fit bit one, I plugged it in for a couple hours and was able to set it up on my account, but it will not track and will not show anything in the display, occasionally when I plug it into the computer and press the button it get the fit bit 6.64 display and the full battery but nothing else. Any ideas? I would appreciate anything
Best Answer05-30-2019 00:12
05-30-2019 00:12
I'm afraid the battery is dead. 😞
I recently lost mine after 6 years but I could tell that the battery was weakening because it was losing its charge erratically. I felt like I lost a part of me.
Luckily I had a brand new spare (back of box said 2012) and when I charged it, it acted like it had a full battery and displayed the fitbit 6.46 but once I disconnected it from the charger, it was dead. I figured the battery drained since it's been sitting around for 6 years. I was devastated.
I gave in and purchased a new one off of Ebay for $130 (gulp! but there are alot pricier ones) but made it sure it wasn't a 2012 one - I bought a 2015. That is still 4 years old but so far so good. I am hoping to get 3 years out of it.
I now attach a pedometer lanyard to it and clip it to my pocket. If you buy a One off of Ebay, make sure you buy one that is more recent and you'll get a few years out of it.
I also purchased the now discontinued Alta HR which can be used with a third party clip. It's like the One but with more features. The Inspire which replaced the Alta can also be used with the clip but I liked the Alta because it's thinner and sleeker.
We sure love our Ones!!! Hard to understand why it was discontinued.
