08-23-2018
18:55
11:30
SantiR
08-23-2018
18:55
11:30
SantiR
So I have a Fitbit one, and it doesn’t set up
Not paired with any phones, and it gives me errors
1) com.fitbit.HTTP error 400
2) com.fitbit.HTTP error 429.
Help so I can pair my Fitbit
Moderator Edit: Format
11:35
06:17
08-26-2018
11:35
06:17
@TheLetterTwo Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing with your One not setting up. Thanks for providing the error message you are getting.
In this case, to prevent those errors from happening; you need to update the Fitbit app on your mobile device. Once you have the latest Fitbit app version you should try the set up process once again. Your tracker should set up correctly.
You could also try using a computer to set it up.
Hope this helps. Keep me posted! ![]()
Best AnswerStill doesn't do anything.
12:39
05:40
12-31-2018
12:39
05:40
@TheLetterTwo Thanks for your reply and for trying the provided steps in order to sort this out.
I went ahead and created a case with customer support in your behalf so you can get further assistance. Please keep an eye on your email inbox for next steps.
