I have had my One for several years now and know how to use the sleep function.
The problem is that it will sporadically NOT log the sleep record.
I specifically wait for vibration, both at night and in the morning.
Not logging happens maybe once a week or so - been working fine for at least 5 or 6 nights, but no sleep recorded this morning. I synced just now for the 2nd time today and still no sleep.
Any suggestions?
Best AnswerI wear it on my non-dominant wrist. Just started happening 2 nights ago (happened again this morning - no sleep registered). But I just now did a reset of the One. Hopefully, that will fix the problem.
Obviously your One is a wristband. Mine is not. It only clips. Do you know if the clip on ones will also track sleep?
The One is designed to be a clip-on.
When purchased, the box contains a sleep wristband.
I recently replaced the sadly worn out wristand with a workout sweat wristband. Cut a little slit in it and popped the One inside. Works great and is actually more comfortable than original that came with One.
