09-13-2017 09:27
09-13-2017 09:27
Was the 2.40 update supposed to fix the no hold charge issue? My ONE will only hold a charge for less that 1 day.![]()
Best Answer09-17-2017 14:55
09-17-2017 14:55
A warm welcome to our new friend @Katers!
please note that the latest version of your Fitbit One is 6.60. These are the improvements made on that update:
Your Fitbit One battery can last up to two weeks. Because battery life is affected by use and other settings, actual results may vary. Consider these tips when you want to conserve battery life:
I also recommend trying a restart:
Hope this helps. Keep me posted! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
