03-28-2019 05:56
03-28-2019 05:56
My Fitbit one will not sync on Galaxy 8 since last update on phone any idea how to get it to work again? Thanks
Best Answer04-07-2019 22:14
04-07-2019 22:14
The workaround I use when my Galaxy won't sync is turn OFF Bluetooth, then hit sync, it will ask if you want to turn ON Bluetooth, hit YES.
Weirdly ... this works! Good luck 😎
Best Answer04-15-2019 08:47 - edited 04-15-2019 08:49
Have you tried removing the fitbit app from the phone, restart the phone, instal the fitbit app?
Also remove the One from the phones Bluetooth list of trusted devices.
Best Answer04-15-2019 09:04
04-15-2019 09:04
Best Answer04-15-2019 11:48
04-15-2019 11:48
Thanks for the suggestion, sadly didn't work but appreciate the time taken.
