07-23-2017
03:44
04:56
07-23-2017
03:44
04:56
Hi,
I know this forum is full of stride length questions but I don't know if I'm doing something wrong with the fitbit math?
I did 130 steps in 0.09 mile (475.2 feet)when I divide 475.2 by 130 I'm getting 3.655...... am I missing out a step because my default stride length is 39 inches so I know it can't be 3...
Any help is appreciated 😊
05:03
10:08
07-23-2017
05:03
10:08
@SunsetRunner 3.655 feet converts to 3 feet 7.8 inches. That is 43.8 inches.
How did you do your measurements? 475.2 feet is an odd measurement to be using.
And is this measurement running or walking? You picture icon shows that you are a woman. I am a tall woman and your number is much longer than my running stride length. Unless your legs are very long/short for your height, the defaults work well for most.
Laurie | Maryland
Best AnswerHi, @SunsetRunner, yes, you are missing a step! You have divided 475.2 feet by 130 steps and you come up with 3.655 feet (ie you cover 3.655 feet in 130 steps). To get to inches you need to multiply that number by 12. So your calculated stride length is actually 43.86 inches (compared to the default 39), suggesting that your stride is longer than your height would suggest. You may want to edit your stride length to give you more accurate mileage. Remember that it will always be a fairly rough estimate, as no one walks (or runs) with a constant stride length.
Here is the help article which discusses how to calculate stride. I would try this several times and take an average.
I hope this helps. Welcome to the forums!
05:03
10:08
07-23-2017
05:03
10:08
Laurie | Maryland
Best AnswerHi @LZeeW I'm 5ft 11 and yes a woman so I'm tall too
I finished my morning 5k run today and thought I'd measure my stride length because I keep forgetting to do it so I ran from the top of my road to the bottom and that's 0.09 miles or pretty much 0.1 miles and the math is to count your steps and divide by the length in feet to which I got 475.2?
I did 130 steps in 0.09 mile so I think that's right? I know nothings 100% accurate but thought I'd try and be as accurate as I could be?
Best Answer@SunsetRunner, yes, your calculation is fine. You just needed one more step, as I mentioned above, to get inches.
I also think, as I said, that to be most accurate you should try this 3 times and then take the average.
08:43
10:08
07-23-2017
08:43
10:08
@SunsetRunner If you want to be more accurate, try doing your measurement at a well marked place like a school track. Most tracks are marked in meters, so you have to convert (1 m = 39.3 in). Or run the length of the football field (100 yds = 300 ft).
I am lucky enough to live close to a trail that has mile markers painted on it. It goes up and down hills, so I get a better average, as stride length can change with changing conditions.
Laurie | Maryland
06:03
10:07
07-24-2017
06:03
10:07
@SunsetRunner How about a football pitch? The penalty box is always 18 yds x 44 yds by FIFA. The center circle is 20 yds in diameter. The endline - endline and touchline - touchline lengths can vary, but I'm sure someone will know the dimensions of that particular pitch.
Laurie | Maryland
