Is your dongle plugged into a usb Port?
With the message you are getting I suspect not
Wendy | CA | Moto G6 Android
If you want it to sync to your computer the dongle does need to be plugged into a USB port
@lizentwoya Welcome to the Fitbit Community! As @WendyB said, the dongle need to be plugged in to your computer for it to sync. It will sync automatically if your tracker is from 15 to 20 feet away from the dongle and you must be logged in to your online account.
If still having trouble, check this syncing master post to get instructions on how to sync your tracker with your computer.
Try that out and let me know how it goes! ![]()
