01-04-2017 08:33
01-04-2017 08:33
I'm new to fitbit and have only had it for 2 weeks. I went into Badges on the app and it lists many that I've "earned". I haven't earned them and the dates indicate before I purchased my new fitbit flex 2 from Macy's. Can I get rid of those badges without loosing all my actual data?
Best Answer01-04-2017 11:39
01-04-2017 11:39
Are they on the Website? Support can help you delete them there.
For the app. Try to Un-install and then re-intsall. If it doesnt wotk contact support
Wendy | CA | Moto G6 Android
Best Answer01-06-2017 02:48 - edited 01-06-2017 02:52
If you hover on a particular badge, you can see a trash icon at the bottom. Click that and it will delete the badge. This doesn't erase your data, at least it hasn't for me 🙂
I've used it for deleting weight goal achieved badges that came up from me not properly setting the goal I wanted.
this is the trash icon I mean
