04-17-2017 14:49
04-17-2017 14:49
All of a sudden my steps on my iPhone are not correct they're not as high as on my actual fit bit and yesterday it didn't update on my phone at all so how do I fix it
Best Answer04-17-2017 21:12
04-17-2017 21:12
Welcome to the forums!
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
Best Answer04-20-2017 13:32
04-20-2017 13:32
@Chateauguay I hope you're doing well! That usually happens when you have not synced your Fitbit tracker. You will not see updated information. If you want to see the actual steps, make sure you have synced.
Please try @WendyB suggestion and if you happen to experience difficulties while syncing your One; try these syncing troubleshooting steps for Android devices. That should fix those syncing issues.
Keep me posted!
