Yes you can contact support. Depends on how old it is if they replace or not
Wendy | CA | Moto G6 Android
Hi there @Brokenclip good to have you in our Community. As @WendyB mentioned before, your can contact our support team for additional help at this link. Optionally, check out Returns & Warranty to learn more about your warranty.
Hope this helps and keep me posted if you need more assistance.
Mine keeps doing the same with daily use as appropriate for product description 😕 They have replaced it twice, and the same has happened again. Worth contacting them for a replacement, or else your ombudsman if it is not replaced. Since this fault is common to many users, it could likely be a design flaw.
Hi @EmilyKate, good to have you here as a new member of the Fitbit Community. Indeed the best option is to contact the Support Team when something similar happens, since they have the tools to review these cases.
Also I'm sorry you have gone thought this and thank you for sharing your experience with us
If you have more questions, just let me know and stay tuned to the Fitbti Community.
