Readd... Sorry I mistyped
Best Answer@PhoenixRain I'm actually more confused by the correction but no worries, I believe you're stating you're unable to perform the firmware update? It's not been updated in years and if it's functioning perfectly without it, I wouldn't be too concerned but would still try as it has a security update. The only feature it adds is turning off real-time data tracking which helps tremendously with overall battery life. Be happy your One is still rocking along! 🙂
