02-03-2016 08:27 - edited 02-03-2016 08:38
While I was sleeping, between 3:30 AM and 7AM, my fitbit recorded over 10,000 steps.
I do not wear my fitbit while sleeping; It was sitting on my nightstand. I do not have sensitive mode on.
Why is this happening? How do I delete this? My calorie burn and everything is all wrong now.
I also tried the "driving" activity workaround, and that did not work.
02-03-2016 09:09
02-03-2016 09:09
Was a fan on? That will cause it to add steps.
Wendy | CA | Moto G6 Android
02-03-2016 15:30 - edited 02-03-2016 15:31
In the search box search for driving. I think you are clicking on the create custom activity that is under the search Box
02-03-2016 09:09
02-03-2016 09:09
02-03-2016 09:20
02-03-2016 09:20
Oh my goodness, yes! Thank you for letting me know.
How do I delete these steps?
02-03-2016 09:36
02-03-2016 09:36
I've done the same thing -- log driving for the time it was counting steps.
02-03-2016 09:40
02-03-2016 09:40
You need to make sure when you log the driving you put it at the same time
02-03-2016 09:56 - edited 02-03-2016 10:02
I did, and it did nothing. The steps are still there.
02-03-2016 11:10
02-03-2016 11:10
Hi @brebre. Are you sure you logged your driving correctly? Your sleep record, say for the one that shows up today, covers the time from bed time last night to wake-up time this morning. So over what time frame did your tracker actually record those 10,000 steps? Did they overlap two dates? If so, you may have to log two driving activities - one for yesterday and one for today.
TW
02-03-2016 12:00
02-03-2016 12:00
It recorded 10,000 steps today, between 4:05 AM, and 6:50AM. I placed the driving for this time.
02-03-2016 12:13
02-03-2016 12:13
Hi @brebre. I just realized that my earlier post was redundant since your initial post already had the times the said false steps were recorded. Sorry about that. So this is two days in a row now with the same anomaly. I would suggest restarting your One, using the instructions in this Help document:
http://help.fitbit.com/?l=en_US&q=restart
You may have to repeat the process two or three times if need be. A successful restart should result in "Fitbit 6.60" showing up on your One's display.
Should the problem persists following a successful restart, then I would suggest getting in touch with Customer Support and see what they can do for you.
Here is the link - http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Good luck!
TW
02-03-2016 15:14
02-03-2016 15:14
02-03-2016 20:08
02-03-2016 20:08
02-03-2016 21:07
02-03-2016 21:07
Glad you got it fixed!
