01-20-2019
02:22
13:05
01-20-2019
02:22
13:05
I just got my fitbit charge 3 a few days ago - first fitbit so apologies if I'm being stupid.
Yesterday I went for a run and my fitbit auto detected and just asked me to confirm. At the end I selected finish and then...there was another option that came up on the next screen to stop autodetection (or something similar) and I hit that.
Seems that turned it off altogether as on today's run I had to manually select an activity and the auto pause etc didn't work. I canicross so my dog stops for sniffing etc every so often so the auto pause is really important.
Does anyone know how I turn this feature back on? I've searched online and looked but just can't figure it out.
Thanks in advance,
01-20-2019 04:21
01-20-2019 04:21
@LyndaK108 Hello, and welcome to the forums. I think this is the answer you need. Go to your exercise app, then go to Run. Swipe up. Make sure that Use Phone GPS and Run Detect are On. Use Phone GPS must be on in order to turn on Run Detect. Happy running!
Laurie | Maryland
01-20-2019 04:21
01-20-2019 04:21
Laurie | Maryland
01-20-2019 04:30 - edited 01-20-2019 05:31
Thank you 😁
01-20-2019 04:50
01-20-2019 04:50
@LyndaK108 Do you have Run on your list of Exercise Shortcuts? On the app dashboard > tap on your Charge 3 icon > scroll down to Exercise Shortcuts. If Run is not on your list, then use the Edit to remove something you don't use. Add Run. When you sync your Charge 3, Run will be on your tracker.
Laurie | Maryland
01-20-2019 05:32
01-20-2019 05:32
I figured it out, was trying to do it on my app on the phone, not the fitbit, sorry. Have it all fixed now, thanks so much 😁
05-24-2020 03:53
05-24-2020 03:53
Hi, I must be really stupid did the same and turned auto detect run off by mistake, how did you correct this on Fitbit, no on app ??
