06-25-2022
04:06
14:14
06-25-2022
04:06
14:14
Charge for using iPhone and Apple’s voiceover screen reader. This morning when I clicked on distance to look at miles walked for past six days and today I noted that one day was red as June 7, one day was red as June 1, and one day was red as August 8, and the rest was red as miles I have communicated this multiple times to the customer service people at Fitbit. I keep hoping that at some point the information will read correctly using the VoiceOver application. It is frustrating to have to convert dates to miles in order to compare the pastg
07-07-2022
12:56
11:12
07-07-2022
12:56
11:12
@Podunk Nice to see you again in the forums. I appreciate you taking the time to explain.
I was informed that you are already in contact with support. I recommend you stay in touch with them for further assistance. I personally do not know of any settings on the Fitbit app that can change this. I assume this is also something more related to the "voice over reader" feature on your Apple device on how they read dates and numbers.
13:52
10:34
07-07-2022
13:52
10:34
@Podunk Thanks for the swift reply and explanation.
I now understand why you wish to use this feature on your smartphone for this app. I appreciate your feedback. I am sorry to read you did not have the best experience with support. However, speaking for myself, I would also have a hard time explaining how to make changes on the Fitbit app to a blind person. I honestly do not know how the smartphone for blind people operates. Hence the reason I would not be able to explain how to proceed and make changes. This is something I can definitely learn and I will make time for it in the future. As of now, I honestly cannot guide you through the Fitbit app.
I have to be honest and have never used the "voiceover" feature with any app before nor do I own an iPhone. However, the fact that this feature reads "distances" as dates is more likely related to their programming, rather than the information on the Fitbit app being displayed incorrectly. I assume that the fact that the distance is displayed with a dot in between, makes this "voiceover" feature read it like it is a date. Since decimals are represented with dots, some distances may be read as dates. For example a distance of 6.09 miles, I am sure it will be read as a date. However a distance if 6.69 miles might not be read as a date, since it does not fall under the "regular" date format. That is the reason I say this is something related to the Apple feature rather than the Fitbit app.
Regarding the step count on the Fitbit app, I am not sure if I understand completely. Do you mean that the amount of steps walked that is shown on the app when you tap on the step tile, locks to this amount, regardless of you walking more steps and syncing your device? I just tried this myself. I opened the app, tapped on the "steps" tile. It showed me 1282 steps. I stayed on this screen, where the step count for today and past days is shown. I did not leave this screen, got up and walked and when I got back the device synced automatically. The step count was updated, even though I remained on the "step count" list for today and past days. I tried this on an Android device though. So there could be some differences. In case on your Apple device works differently, I suggest you back out to "Today" and then tap again on the "steps" tile in order to get the updated step count on that list as well.
14:43
10:34
07-07-2022
14:43
10:34
@Podunk Thanks for the reply and explanation. This certainly gives me an idea, but I do not own an iPhone. Hence I cannot try it myself. Hope you understand.
Regarding the step count, I suggest you just back out to the "Today" tab and then tap again on the "step" tile, so that the step count on that list is also updated. That would be my solution to this situation, given that it recently changed.
Best AnswerDistances only show up when they’re displayed in pants examples seven die for July 4 8.7 August 7 3.2 March 2 eight dodge zero would show up as a god zero not as the day 5.31 which shall walk as distance not as a day hope this is helpful
07-08-2022
14:13
05:29
07-08-2022
14:13
05:29
@Podunk Thanks for the reply. Understood. I am very sorry, however, there are no settings that can be changed to help you out with this situation. It seems that this feature is reading numbers according to their algorithm. Distances are regularly represented with decimals and these decimals use a dot. That is the reason I believe this feature reads the distances as dates.
The fact that numbers are read as dates by the "voiceover reader" from Apple, is something we from our side at Fitbit cannot change. Even though distances were to be shown differently on the Fitbit app, there is no guarantee these will be read as you expect. Have you tried contacting Apple regarding this feature on their device? I would recommend you do that as well.
Have a nice day.
