09-27-2019
09:50
12:16
09-27-2019
09:50
12:16
Hi, I have had my Charge 2 for about two and a half years now and over the past few months, I have noticed that the battery will drain from 100% to 0% in less than a day. I have looked at other comments in the community posts about this same problem and I have done what they suggested which has helped some but my battery will still be drained after a little over a day. Is this simply because I have had this device for so long and the battery life has diminished or something else?
09-28-2019 07:11
09-28-2019 07:11
In a word, yes.
Best Answer09-28-2019 18:00
09-28-2019 18:00
can I replace the battery or will I just need to buy a new one?
Best Answer09-29-2019 07:47
09-29-2019 07:47
Try this, see post 26.
My battery was dying in less than an hour. I did the above, now it's holding a charge like normal. My last full charge lasted 7 days.
Best Answer09-29-2019 10:51
09-29-2019 10:51
thank you!
