03-30-2017
13:57
09:49
03-30-2017
13:57
09:49
Hello
Charge 2 will not let me add my name . Can anybody help please ?
03-30-2017 13:41
03-30-2017 13:41
Hello . Can somebody please help me . I'm trying to change my distance from km to miles . I've found out you have to change the setting to centimetres , is that correct ?
BUT .... It will not let me submit it because it is telling me to add my name ! ... it will not accept anything I type in .. I'm very frustrated . Can anybody please help ?
Best Answer03-30-2017 13:41
03-30-2017 13:41
Best Answer03-30-2017 14:09
03-30-2017 14:09
@Angelicrose12 Have you inputted both your first and last name? Also, have you followed the instructions listed here?
Keep me posted.
03-30-2017 14:09
Are you referring to the setting for the greeting?
What is happening that it won't let you?
When you click on Greeting, does an input box open up?
Is there an OK button to press?
Do you get any errors?
Also it might be helpful to know the type of phone or if your entering it through the web browser.
This would allow me to try and replicate the problem.
Best Answer05-01-2018 06:37
05-01-2018 06:37
It will allow me to input my first name but not my last name. Help!
Best Answer06-18-2018 18:33
06-18-2018 18:33
Was there ever a solution to this? I cannot change to 24 hour time unless I add my last name, but it won’t allow me to add my last name.
Best Answer08-07-2018 06:47
08-07-2018 06:47
Hi, Did you get an answer to this? I have the same problem. 🙂 Let me know? Thanks
Best Answer08-07-2018 07:43
08-05-2019 03:50
08-05-2019 03:50
I’m having the exact same problem. Any luck?
