06-14-2017
15:04
09:49
06-14-2017
15:04
09:49
I haven't decided to buy the charge 2 or the blaze yet, but for now one the biggest factor is the bezel size. So I need to know bezel size of the charge 2 is, and if you can, may you also tell me the bezel size of the Fitbit blaze? (By the way, there is a post for the bezel size of the blaze, but all of the words and numbers in the answer are really confusing me. I just need to know the space between the actual screen and the edge of the little square that you snap into the band.)
If you go to this page: https://www.fitbit.com/compare, and scroll down a bit, there's a nice big photo of the Charge 2 and Blaze side-by-side. As you can see, there's no real rim on the Charge 2--the screen extends to the end. The Blaze has a sizable bezel (don't know the dimension), which was one reason I went with the Charge 2.
Best AnswerReally? When I looked down at my charge 2 (I got one) if I looked closely I can see that it has about 1/2 cm of bezel around the edges.
