01-26-2019
13:47
17:54
01-26-2019
13:47
17:54
My watch said 22,000 steps and when I synced my phone it onlt registered 15,000 steps then I looked at my watch and it changed to 15,000 - very strange!
Moderator Edit: Updated Subject for Clarity
@Shirleyab Welcome to the Fitbit forums! I moved your post to the Charge 2 Board as there are more chances for you to get an answer to your inquiry here.
Thanks for reporting the situation you experienced with your Charge 2 loosing steps. It is very strange indeed.
Is this the first time that this happens to you? I'd recommend performing a restart on your tracker. This should refresh its inner components and should help you out.
You can also manually add the lost steps at the online dashboard if needed.
Hope this helps. Keep me posted! ![]()
