09-28-2018
16:35
18:22
09-28-2018
16:35
18:22
09-29-2018 06:20
09-29-2018 06:20
Hey @Darknight74! Welcome aboard! If the screen of your Charge 2 is not responding at at all, even after you tried to restart it, our Support team will continue assisting you with this. I have escalated your case with them, so please keep an eye on your inbox.
Let me know how it goes!
09-29-2018 06:20
09-29-2018 06:20
09-29-2018 17:04
09-29-2018 17:04
Hey there just wanted to say thank you for your help. Your colleagues have been nothing but helpful and the issue is sorted. I have never had such a high standard of customer care. Thanks to all.
Best Answer10-01-2018 06:18
10-01-2018 06:18
I really appreciate the update @Darknight74! Sounds awesome that our Support team has helped you out with this. I know, they are simply the best and always try to get the best option to get the users back on track. 😉
If you have further questions or comments, keep me posted!
Best Answer07-10-2019 07:57
07-10-2019 07:57
OK. So what is the solution. My screen went dead this morning. Green LED's are working. Reset doesn't seem to work, and I appeard to be synced with the app as HR and steps are updating. Is this how our relationship ends FB?
07-11-2019 01:54
07-11-2019 01:54
Best Answer07-11-2019 03:54
07-11-2019 03:54
Im having the same issues woke up the 8th of july to find my fit bit screen blank, still syncs and vibrates but not screen! Who do i contact to send back and see what i can do to fix it? I feel lost with out it, Please Help!!!!
Best Answer07-11-2019 07:05
07-11-2019 07:05
Hi there, you want to speak to the moderator on this post who is called heydy she provided the solution and resolved my query. Hope this helps.
Best Answer10-13-2019 14:23
10-13-2019 14:23
I too have a blank screen on my charge 2. Initially the screen appeared to split & show everything twice. Then all down one side was a strip of dots so I couldn’t see half the info. Then within a matter of minutes it went completely blank.
what can I do?
10-29-2019 11:18
10-29-2019 11:18
Hi, I'm having the same issue screen is blank but my Charge 2 is syncing. A restart hasn't had any effect.
11-25-2019 21:40
11-25-2019 21:40
Hi
I'm having the exact same issue. I've had my FitBit Charge 2 for less than 2 years.
But when I contacted support separately, outside of the forums, they just offered me a 25% discount for my next purchase.
No explanation. No help. No solutions.
Please let me know what the solution to this is. I love Fitbit. We already have 3 devices in the house and I was considering upgrading as well.
Any help would be appreciated. Thanks!
Best Answer11-26-2019 03:58
11-26-2019 03:58
Best Answer12-05-2019 15:26
12-05-2019 15:26
My screen has done the same thing. I too have done resets and they have not worked. I am very disappointed as this is not my first Fit Bit and I had an issue with the last one I had. Are these only made to last for about a year?
Best Answer12-14-2019 19:25
12-14-2019 19:25
You are not alone, thousands of people are frustrated with the latest update, no heartrate, blank screen, no detailed sleep cycles, charging problems
Best Answer01-23-2020 21:32
01-23-2020 21:32
well, my Fitbit charge 2 has died. I guess I shouldn't complain as I've had it since March 2017. It's a Charge 2 and it still syncs fine, but the screen went blank last night. I got the 25% offer on an upgrade,but I prefer this model and I have a kzillion bands for it from amazon.
Best Answer08-14-2020 06:22
08-14-2020 06:22
My Charge 2 screen just went mostly black this morning.
When I press the button I can briefly see some lines, but that is it.
Upon resetting it, the watch vibrates, but nothing comes on the screen.
I have also tried changing the clock face via the phone app as someone else had suggested.
So far my watch is still black, but is still tracking my steps, heart rate and exercise.
I am really hoping that this is an issue that can be fixed.
Thanks very much!
Anne
Best Answer10-09-2020 12:45
10-09-2020 12:45
Fitbit Charge 2 HR, bought for missus in January 2017. Died this morning and after reconnecting it to USB and trying to reset, it showed a load of 1s & 0s after briefly showed the fitbit logo. After reconnecting it to USB again screen went blank and has stayed blank! Searched the internet for a solution and had no luck. So, what to do now? Well fitbit Charge 2 is going into the trashcan, and the Versa 2 my wife bought for me is going up for sale. I shall be looking elsewhere (maybe Garmin or something), and as for all my friends, well I won't be telling them to invest $/€ 250 plus in a Fitbit this Christmas!!
04-12-2021 14:18
04-12-2021 14:18
My Fitbit charge 2 screen is blank too. Syncs, vibrates and green lights are still on. Also have a full battery showing on my app but screen still blank. Have made sure all connections are clean and dust free. Re started it several times and the screen is still blank. Is there a way to fix this without buying a new one?
Best Answer04-12-2021 15:19
04-12-2021 15:19
04-12-2021 15:28
04-12-2021 15:28
Thanks but as this is the third Fitbit that has either gone wrong or died since I started with Fitbit I think I will go elsewhere if I have to buy yet another one.
