12-01-2017
03:56
18:54
12-01-2017
03:56
18:54
Hi,
I’ve had my Charge2 for 2 days now and I have noticed that it’s always counting steps while I’m sleeping. It’s averaging less than 100 steps but was wondering why this is happening. I checked the forum yesterday and tried the suggested solution of changing the sleeping sensitivity. But it didn’t work. I would really appreciate the help.
12-01-2017 04:48
12-01-2017 04:48
It is probably from tossing and turning throughout the night, and maybe a trip to the restroom. Unless you don't realize that you sleep walk, this has happened to others.
Best Answer12-12-2017 07:30
12-12-2017 07:30
I am having this problem too. I have worn the fitbit Charge 2 for a week now and every night I log hundreds of steps. I do not sleep walk. Going to the bathroom would log maybe 30 steps at most. Moving in one's sleep should not count as steps; that's a poorly designed product. It is extremely rare that someone stays as still as a corpse during a night's sleep.
Please inform us how to fix this problem if you're a Moderator or provide information on how to get a replacement that works properly. My sister has the same device and hers does not log sleep steps.
12-28-2017 04:12
12-28-2017 04:12
My fit bit charge 2 counts steps while i am asleep, No I do not sleep walk and no I do not get up to use the bathroom, does anyone know how this can be fixed!
12-28-2017 08:02
12-28-2017 08:02
How many steps are we talking about @Kendralee? Have you read my post above?
Best Answer12-28-2017 12:59
12-28-2017 12:59
It looks like we both referenced your post above.
Turning in one's sleep is normal and shouldn't be counted as steps. And it shouldn't account for hundreds of steps. When paying $150 plus for a product that counts steps, we should get an accurate count, not have to subtract what's there in the morning or adjust the goal each day to factor the sleep "steps" out. Is there any fix besides saying "oh well, you toss in your sleep?" Those posts have been marked as a "solution" but the problem isn't solved.
Thanks.
12-29-2017 04:38
12-29-2017 04:38
Mine dos the same and counts the steps wen moving my arm sitting down can anyone solve this problem
12-29-2017 04:47
12-29-2017 04:47
It’s happening me to and I dnt sleep walk so what’s ur answer to that please??
Best Answer12-29-2017 06:43
12-29-2017 06:43
Best Answer12-29-2017 06:46
12-29-2017 06:46
Between 77-30 steps while sleeping I contacted fit bit they said 5-7 would be normal we reset the fitbit however it still logged 30 last night
Best Answer12-29-2017 07:23
12-29-2017 07:23
@Page44 I agree the problem hasn’t been solved, so I proceeded with unresolving the post. Hopefully someone from Fitbit will provide a solution.
Best Answer12-29-2017 07:26
12-29-2017 07:26
Best Answer12-29-2017 07:34
12-29-2017 07:34
Best Answer12-29-2017 07:36
12-29-2017 07:36
Best Answer12-29-2017 07:39
12-29-2017 07:39
Best Answer07-12-2020 05:04
07-12-2020 05:04
Fit bit charge 2 counts steps in my sleep on normal not sensitive settings. Please help
Best Answer07-12-2020 18:57
07-12-2020 18:57
Mine does sometimes too if I have a restless night. I usually log about 8-10 steps I'd your logging more than that I would call customer service. They will get you on the right track
Best Answer07-14-2020 06:16
07-14-2020 06:16
Thank you did you end up keeping yours ? ready to send mine back
Best Answer07-14-2020 10:37
07-14-2020 10:37
