02-01-2021 09:05 - last edited on 02-01-2021 15:58 by LiliyaFitbit
My charge 2 keeps needing to be hard reset every few hours help plz
02-01-2021 10:09
02-01-2021 10:09
What symptom(s) specifically make you think you need to do a "hard reset"?
What precisely do you mean by "hard reset"?
Best Answer02-01-2021 11:48
02-01-2021 11:48
I get nothing on the screen when i try and recharge and it wont charge untill i hard reset it comes up when it is working with the fitbit logo and version but there is no update that i can see on the app i think i am look in all the right places
Best Answer02-01-2021 11:51
02-01-2021 11:51
Hard reset i pluged the fitbit in to the chager and hold down the button for about 10seconds
Best Answer02-01-2021 12:05
02-01-2021 12:05
Sorry, still not quite understanding. It sounds like you have to charge it so plug into charger, get no display so do a "restart" (Fitbit's term for what you are calling "hard reset"), then it charges okay. But then, are you saying the charge runs out in a few hours so you have to charge again?
