11-15-2016
04:33
10:26
11-15-2016
04:33
10:26
Not sure what happened, won't turn on, won't charge. Was fully charged.....a few hours later, its off and won't come back on.
Help?
For the record my ACCEPTED SOLUTION was to contact support
11-15-2016
15:50
04:41
11-15-2016
15:50
04:41
@hendersondayton If your battery is still not charging, I would recommend the tips mentioned here to help get you back on track.
The tips should help, but if for some reason they don't, I'd then recommend reaching out to Fitbit customer support for additional help.
Hope this gets you back on track.
11-15-2016 04:39 - edited 03-06-2026 04:41
It's nice to see you around @hendersondayton! First of all, to make sure is not the battery what died, I'd recommend leaving your Charge 2 charging around 2 hours or so to see if any sign of light comes up. If after that period of time you see that your tracker is not turning on I'd recommend restarting it at least 3 times in a row by doing the following:
Let me know if that works!
11-15-2016 04:42
11-15-2016 04:42
If there is no battery, will the fitbit vibrate when its plugged in?
Best Answer11-15-2016 05:05
11-15-2016 05:05
No my friend @hendersondayton, it won't vibrate due to the empty battery. Let me know if it turns on after 2 hours into the charger. I'll be here!
Best Answer11-15-2016 08:06 - edited 11-15-2016 11:20
OK. Its been plugged in for 3 hours right now...still not turning on.
Edit: Its now been charging for 7 hours. Still not turning on.
15:50
04:41
11-15-2016
15:50
04:41
11-15-2016 17:05
11-15-2016 17:05
this might sound a bit dopey, but are you sure you have the charge positioned properly on the tracker? you should almost hear a click to know its locked in properly. Reason I ask, I didn't know or realize initially that it had to be snug in the clasp. I attached it, it looked right, I went about my business. I came back an hour later and it had the exact same battery level. I wiggled it and heard the click. All was well.
Elena | Pennsylvania
11-15-2016 17:23 - edited 11-15-2016 17:24
not a dopey suggestion at all. I did make sure it was connected. I also did the rubbing alcohol thing....so far, still nothing.
I did 3 hours on USB and 3 hours on USB/Wallcharger.
01-18-2018 23:57
01-18-2018 23:57
my fitbit charger 2 , is not working , all it says is www.fitbit.com/setup
i have charged it, its been plugged into my laptop as well and still nothing, i have logged out the app on my phone logged in and still nothing??
Best Answer01-19-2018 04:16
01-19-2018 04:16
Hello @louis-london the message you are seeing is telling you to setup the tracker.
Best Answer05-13-2018 09:50
05-13-2018 09:50
Will not turn on and will not seek with Bluetooth to the iPhone.
Best Answer02-02-2019 10:42
02-02-2019 10:42
I was able to get the fitbit to work but why does it stop? what makes it stop working?
Best Answer08-01-2020 17:51
08-01-2020 17:51
That didn't work for me. I did get a smiley face, but the clock face is not visible. Just a straight line.
