01-06-2020
13:35
19:53
01-06-2020
13:35
19:53
I have owned my Charge 3 for just over a year (approx. 14 months). My band broke yesterday, with the rubber splitting so that I can no longer faster the band. The larger band is too large for my wrist so I am no longer able to use my band effectively! I have used the waterproof feature of my Charge 3, but always made sure to dry it thoroughly after getting it wet. Has anyone else has a similar problem? It is very annoying that the bands appear to only just last through the first year and then start breaking!
01-06-2020 13:43
01-06-2020 13:43
Welcome to the forums!
They do go through a lot of wear and tear. You can buy a new one in the store.
I keep a couple around as I also like to change the look of it as well. They seem to last longer.
Amazon has them as well
Wendy | CA | Moto G6 Android
Best Answer01-06-2020 15:39
01-06-2020 15:39
I had the exact same thing, same timing too. I contacted customer support and a bit of back and forth with photos and they posted me a new strap. Worth a try.
