06-16-2020
08:27
10:19
06-16-2020
08:27
10:19
My Charge 3 has a black screen. When I plug it in and hold the button down, it sometimes shows a progress bar and/or a smiley face, but nothing further happens. It does not sync to the fitbit app on my phone. Please help!
06-16-2020 08:28
06-16-2020 08:28
@AndyP13 Have you tried changing the clock face in the app or performing a factory reset?
If those things don't work, then I'd recommend you reach out to Customer Support. Best of luck!
Best Answer06-16-2020 08:28
06-16-2020 08:28
Best Answer06-16-2020 08:31
06-16-2020 08:31
Thanks for reaching out. Yes, I am unable to change the Clock Face. "The clock cannot be installed on your device. Your device is not connected." I will try Customer Support.
07-15-2020 10:36
07-15-2020 10:36
This is also happening to mine. The only thing that happens is the smiley face. Black screen after smiley face and isn't recognized to sync.
