05-17-2020
13:39
08:53
05-17-2020
13:39
08:53
I was having trouble seeing anything on my screen outdoors. Took the advice given in the help section to change it to auto and my screen went black. I cannot see anything to turn it back to normal. Tried other recommended fixes. Nothing works!
05-18-2020 18:32
05-18-2020 18:32
Welcome to the Fitbit Community, @SunsetRunner.
I've moved your post to Charge 3 board so we can keep our forums organized.
I am sorry to hear the screen on your tracker went black after changing the brightness setting to "Auto". Thanks for trying to resolve this, I totally understand how you are feeling and I am here to help. Have you tried to restart your tracker: How do I restart my Fitbit device?
You may also try changing a clock face: How do I change the clock face on my Fitbit device?
Looking forward to hearing back from you.
Best Answer05-18-2020 19:52
05-18-2020 19:52
I also have the same problem! At first the screen started to have lines across them and the screen slowly started to disappear. I charged it overnight, held the button down while charging, all of the tips recommended, and now it's completely blank!
Best Answer05-18-2020 23:20
05-18-2020 23:20
I have the same problem. My device was purchased 3 months ago. None of the fixes suggested have worked. I also note that this problem has been reported since the end of 2018. Why have Fitbit not provided a permanent fix yet?
Best Answer05-18-2020 23:33
05-18-2020 23:33
I have the same problem. I have tried to change clock face. Doesn´t work. I cant restart it, because the screen is black? Can I do that frpm the app? I don´t want to loose any data.
Best Answer05-19-2020 05:06
05-19-2020 05:06
Best Answer05-19-2020 08:16
05-19-2020 08:16
Exactly the same thing happened to mine too!
Best Answer05-19-2020 08:22
05-19-2020 08:22
Hello, I have the same problem as do several others that I can see. I don't understand how rebooting my device will work as I can't see anything on the device, so following your procedure simply doesn't work! Please advise
05-19-2020 08:32
05-19-2020 08:32
Please can you tell me how I can restart my device when my screen is completely black?
05-19-2020 08:39
05-19-2020 08:39
Same issue here. Can feel it pulsing, but won't reset or start
