05-24-2024
17:05
08:40
05-24-2024
17:05
08:40
When logged into account it shows battery full. Vibrations are working but the display is black. Is there a way I can fix this?
Hi there, @Ezra10-4. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 3. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend the following steps:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
