01-16-2020
00:34
17:47
01-16-2020
00:34
17:47
Not totally happy with the charger on my Charge 3, should the pins be straight or leaning over? I have to balance it carefully and keep a check on it to see if it is charging or has moved.
Welcome to the Community, @caroled77.
If you are having problems charging your Charge 3, I recommend taking a look at the help article: How do I charge my Fitbit device?, where you will be able to see the best practices to charge your unit.
Let me know if you need anything else. 🙂
