06-14-2020 05:10 - last edited on 09-16-2020 10:22 by
I have a charge 3 that normally tracks workouts automatically very well, however it doesn't ever track the GPS information as well. Despite my phone being with me during the workout and connected to my charge 3 device via blue tooth. When I track a workout intentionally with GPS it works but then I don't get the associated heart rate information that I would get from an autotracked workout without GPS.
Why is this?
06-15-2020 02:49
06-15-2020 02:49
Is it the same issue I am experiencing?
When I try to start an exercise (run or walk), the device will not connect to my phone unless the app is open on my phone. I did not realise this was an issue until a couple of exercises were not showing a map or syncing to Strava. I can get it to work, but only by keeping the app open on my phone, and not allowing the phone to ‘sleep’ or go to the lock screen. Very annoying, as doing anything else on my phone will result in the GPS connection being lost, and exercise information being incorrect/incomplete.
I have contacted support but they have just told me to try multiple steps which I have already done.
06-15-2020 09:44
06-15-2020 09:44
Try going into the settings for your Fitbit app and change the "location" to "always". I was having the same issue, before I had it on "while using the app".
I usually change it to this right before I go walking and then change it back when I'm done.
06-16-2020 05:22
06-16-2020 05:22
Thanks for the suggestion, I checked and my location is set to "always" already 😕
06-16-2020 05:24
06-16-2020 05:24
I don't think the issue is quite the same. For me the problem is specifically with the "autotrack" feature. I can manually start a GPS tracked exercise but when I do this the heart rate zone information does not get recorded.
When I don't manually start a GPS tracked workout and just let the fitbit automatically detect the walk/run/cycle, the GPS information is always missing.
06-16-2020 09:20
06-16-2020 09:20
06-17-2020 22:57
06-17-2020 22:57
Sure as I said, this will track an exercise with GPS but none of the heart rate information is then present in the exercise activity that normally would be if I track an exercise without GPS activity. Further more one of the features of the charge 3 is the auto exercise tracking. I expect that the product should function as advertised and not be an either or situation where I have to choose between auto tracking and heart rate information or the GPS route tracking information.
06-18-2020 03:28
06-18-2020 03:28
